07-12-2006 02:45 PM
07-13-2006
07:02 PM
- last edited on
04-25-2025
12:57 PM
by
Content Cleaner
Hello Henry,
At this moment it not clear to me why LabVIEW would not talk to you TCP/IP instruments. TCP/IP communication is based of an IP address and a specific port. So if you know you TCP/CP ip address then you should be able to talk easily to your instrument. Do you have an application setup in LabVIEW to talk to you instruments yet? If yes, than what kind of error are you getting? Also, do you have the modus LabVIEW libraries installed? If not, then you can download and install then from here.
Chetan K
Application Engineer
