Terminal name not found
Hi all , Here's something simple that i want some help with. I want to use the block " sign " , which returns the sign of the number that you feed in. I am using my labview with a DSP target (speedy 33) . I input a negative value to the sign block hoping to get a -1 at the output , but to my amazement , it returns the error " Internal - terminal name not found " ... i tried restarting the computer , hoping that might help . didn't work . does the same on two different computers . what does this error signify . any suggestions please ? ... Mano ...
(2,699 Views)
Accepted by topic author NonameNoface
Hi Mano,
Wow, I apologize for what appears to be a blatant error!  I have notified our R&D department of this issue, and I will keep you updated.  In the meantime, please use the attached VI as a workaround.
(2,647 Views)
