Tensorflow Python Node breaks after weights load
Hello everyone,
I'm trying to run python node in LabView, but script return error 1672.
With script everything ok, but LabView have some problems.
Message 1 of 11
(5,683 Views)
Hello, NoKot333. Do you use any Numpy functions?
Message 2 of 11
(5,636 Views)
What is your LabVIEW version?
Message 3 of 11
(5,629 Views)
Message 4 of 11
(5,617 Views)
Accepted by topic author NoKot333
I can confirm, I have seen error 1672 when returning a numpy array which is generated by the python script
in the following, I write a 2d buffer to the python node, extract the first column of this 2d buffer, convert this column vector to a numpy array and return as 1d array of doubles "y".
import numpy as np
def return_cm(data):
    y = data[:, 0]
    X = data[:, 1:]
    y = np.array(y)
    return y
the length of the y-vector can be manipulated by choosing a different number of rows, in the following screenshot 1000:
Error 1672 does halt the .vi, when the numbers of rows in this vector is bigger ~ 10.000 , but will work corretly if less e.g. 1000
Message 5 of 11
(5,603 Views)
There are some Numpy functions, which are not supported by LabVIEW.
Message 6 of 11
(5,583 Views)
Hello again. Can you send me kwhFinal.h5 for testing code on my PC?
Message 7 of 11
(5,574 Views)
Yes
Message 8 of 11
(5,540 Views)
21.0.1 (64-bit)
Message 9 of 11
(5,539 Views)
