Temporarily stop data acquisition by external trigger
Another approach to consider:
Stream the data and the trigger line to disk as one complete capture lasting the full duration of the run then post process the captured data to remove the portions where the trigger line indicates bad data, this should remove any of the delays in stopping/ starting the recording, if you create the code to do the record then go straight in to the post process I don't think it will add too much time to the overall task, the 6024 board should be capable of far higher speed than  2KS/s on a couple of channels - Mike
Message 11 of 12
(501 Views)
Thanks to you all, problem has been solved with the initial suggestion and some changes to the rest of my code!
Message 12 of 12
(491 Views)
