Temperature difference measurements
I've been working with LabVIEW 2018 code that allows me to activate a "Steady State" LED indicator when the temperature change is less than a certain amount (0.4 deg C/min). I'm wanting to measure the current temperature output, and then the temperature output from 1 second ago. I can't seem to get this to work. I'm using a cDAQ-9184 to record the temperature data from some thermocouples.
(1,191 Views)
Hi divide,
The reason is "THINK DATAFLOW!"
This is your VI after using AutoCleanup:
  • That 2nd loop is only executed AFTER the 1st one - due to THINK DATAFLOW!
  • It is also nonsense to wire the same value twice to the 2nd loop - and then subtract both IDENTICAL values to check their difference!
You need to use a shift register in the 1st loop to keep previous values for next iteration(s)!
(1,144 Views)
I'm trying to store the past value, and then subtract it from the current reported value. I've tried finding what a shift register is but I haven't found much useful information on how to use it properly and what it does exactly.
(1,110 Views)
@Divide204 wrote:
.... I've tried finding what a shift register is but I haven't found much useful information on how to use it properly and what it does exactly.
See here
"Should be" isn't "Is" -Jay
(1,092 Views)
