Temperature Measurement
i have already downloaded the attaches file, which is a tutorial of my temp (Pitsco kit attached to my daq to measure the temp by seven thermistors of  7 channels) every thing is ok but i cannot write the outputs of the seven channels into excel file (Time versus temperature).Hint : time format needed
is( dd/mm/yyyy hh:mm:ss.000).Many thanks
Message 1 of 8
(3,950 Views)
Hi zambizo,
i cannot write the outputs of the seven channels into excel file (Time versus temperature).Hint : time format needed is( dd/mm/yyyy hh:mm:ss.000).
Why can't you? What's the problem?
You already get 7 temp values.
All you need to do is to determine the elapsed time so far (hint: there is a function called "Elapsed Time"!) and format the given value as needed into a string (hint: there is a function called "Format Into String"). Then you append the temp values (also formatted into string) and write them all into a spreadsheet file (hint: there is a function called "Write Spreadsheet File")…
Try on your own and ask for specific problems! 🙂
Message 2 of 8
(3,938 Views)
i will try it now and i will feed back with you,many thanks
Message 3 of 8
(3,934 Views)
As i haven't any background about the lab view,kindly show me more details about what i have to to ,the block diagram is attached, i need to write the output of the seven channels instantaneously  in to spreadsheet file with the previously mentioned time  format,so kindly give me more details
Message 4 of 8
(3,909 Views)
Message 5 of 8
(3,907 Views)
Hi everyone
until learning LV ,i need some help for building of string and spreed sheet .
Message 6 of 8
(3,895 Views)
Hi zambizo,
did you play with all those functions I mentioned before?
They all have nice articles in the LabVIEW help, so you can also read about them…
Message 7 of 8
(3,888 Views)
For 2015 and newer, https://www.ni.com/docs/en-US/bundle/labview/page/writing-to-spreadsheet-files.html
For 2014 and older, http://zone.ni.com/reference/en-XX/help/371361L-01/lvhowto/writing_to_spreadsheet_fil/
Message 8 of 8
(3,887 Views)
