Telnet error (Code: 62)
I'm running VIs (LV8.6) under TestStand 4.1.
The following message is from a Telnet Read/Write vi.  I usually open the Telnet connection at the beginning of the test and close it at the end.  Sometimes there is a gap of long time without any telnet activity.  I set the timout of the Telnet connection to 1 hour.
Any idea what this error mean?
------------------------------- Run Time Error ----------------------------------------------------
A Run-time error has occurred in step: Remove All clocks Priorities
Sequence: Select_TMU_input
SequenceFile: D:\views\quad3_HLXC1536\NPI\TESTER\Work\HLXC1536\Seq\HLXC1536.seq
Error Message: TCP Read in NI_InternetTK_Core_VIs.lvlib:Telnet Buffered Read.vi->NI_InternetTK_Core_VIs.lvlib:Telnet Read.vi:1->TelnetReadWrite.vi->TelnetReadWrite.vi.ProxyCaller
Error Code: 62
Rafi
(5,209 Views)
The error code means:
The system caused the network connection to be aborted.
It's possible that the device you are telnetting into is timing out and closing the connection. In general I find it much more relaible to open a connection, use it, and then close it before long periods of inactivity.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,196 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=208743
Error 62 occurred at an unidentified location
Possible reason(s):
LabVIEW:  Serial port overrun error.
LabVIEW:  The system caused the network connection to be aborted.
Something in your system the connection is closed.
Either find the cause or open and close each time you have communication,
André (CLA, CLED)
(5,195 Views)
