Task scheduling and Status of copying files from one folder to other
In the attached VIs I am reading the content of a Folder from Harddisk and reading the contents of the FTP folder, then after comparing the contents or both folder I am copying the missing data to the HDD from FTP. I've two issues here,
1) Can any body tell me how I can check while VI is running , that how much data is copied from FTP and how much is remaining.
2) What if I want to do this task each day but at particular time lets say 1 p.m each day this task should be perform but the vi will be in run mode all the time.
I hope I will get some suggestions and help from the members.
Naqqash.
Naqqash
(4,045 Views)
Hi Naqqash,
An idea for to set-up, you could insert a seperate case structure where the Case Selector is based on a comparison between the "Get Date/Time String" or a timestamp and 1pm, and when that's true, the case launches a sub VI that checks this process, displays the result, then closes when done. In that subVI, go to File>>VI Properties>>Window Appearance>>Custom>>Customize and then check the box 'Show front panel when called'.
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(4,019 Views)
Thank you very much. Any idea for that copying status thing.
Naqqash
(4,011 Views)
Please don't duplicate forum posts. New forum has been started for this, Here.
Deborah Y.
Deborah Burke
(3,977 Views)
