Target support for FPGA
Hello!
I have an error and I don't now how to fix it...the error is
Block Diagram Errors:
Close FPGA VI Reference: target support for selected FPGA device is not installed
Details:
Install the correct support files
I have already installed all CDs from NI (FPGA,RIO,Real...)
I will be glad for every help...thanks
by
(4,584 Views)
Not really too obvious but.....you need to install things in the correct order as follows
FPGA
RIO
Device Drivers
Hardware
"Should be" isn't "Is" -Jay
(4,576 Views)
If you reinstall NI-RIO and you are still having issues, please let us know what version of LabVIEW, LabVIEW FPGA, and NI-RIO you are installing.  Also let us know what FPGA hardware you are using.
(4,572 Views)
Maybe report from MAX would be better. And be sure you have activated FPGA module, or evaluation is not expired.
(4,546 Views)
I reinstall NI-RIO...same error
report from MAX:
LabVIEW 8.5.1
LabView FPGA 8.5.1 (no FPGA hardware)
NI-RIO 2.4.0
(4,539 Views)
What FPGA target are you trying to use?
(4,496 Views)
