Tank Simulation Example
Please can you explain the working of this VI.
What are the farmula constructed in the Sub-Vis?
Message 1 of 9
(8,349 Views)
Since all the work is done in the subVIs, we cannot tell what they do unless you post them.
Lynn
Message 2 of 9
(8,342 Views)
This VI is an example in LV 2009.
Find example-Industrial example-process
Message 3 of 9
(8,333 Views)
Sub-Vis
Message 4 of 9
(8,328 Views)
Message 5 of 9
(8,327 Views)
Hi KRAZE4LV,
The purpose of the example is to create a simulated tank control environment that you can manipulate to be functional for your application.  The example uses a random number generator, but you could easily change this to read data from a tank set up.  The example displays a history of the inflow, level, and temperature in the three graphs for your record.  There are also a set of parameters that you can set depending on what type of tank you have.  Those parameters are the tank level, tank temperature, inflow rate, and inflow temperature.
Do you have specific questions about the functionality of one of the subVI's?  The easiest way to learn about the different functionalities within each subVI is to use the Context Help, which you can display by pressing Ctrl+H.  From here, you can hover over each function and see what its functionality is.
To explain a few of the more complicated subVI's, the Temperature VI takes in a set of metrics from the tank and performs an equation to find the new fluid temperture.  Based on inputs to the boolean change VI, it will determine whether the output booleans are set to true or false which will in turn change the heat inflow rate.  I hope this is partially helpful.  Like I said, if you have any specific questions, those would be much easier to answer than to try to describe the functionality of the entire VI.
I hope this helps!
Kim W.
Message 6 of 9
(8,297 Views)
Thank you VT Kim!
Message 7 of 9
(8,290 Views)
i am currently working on simulating the sloshing pattern of liquid in a tank subjected to vibration . the level of liquid in the tank available in labview can be changed ... but i would like to know how the surface pattern of the liquid in the tank can be changed and not the level itself !!
Message 8 of 9
(7,768 Views)
Yoru problem is completely different from the problem in this thread. It is a wave mechanics or computational fluid dynamics problem.  Please start a new thread. Include as much specific information about the parameters of the problem as you can.
Lynn
Message 9 of 9
(7,736 Views)
