Tachometer
Until now i have made what you can see in the file. I cant find the rest of whats missing in the diagram?? Can you please help me?
Message 11 of 12
(659 Views)
You will want to wire through the false case from tunnel to tunnel.
You will want to wire the tunnel from the case structure to the edge of the while loop.
Put an indicator on that wire.
Right click on the tunnel that is on the while loop and change it to a shift register.  That way the count is stored from iteration to iteration of the while loop.
Message 12 of 12
(638 Views)
