Table.ctl, cell background colour
Hallo,
I have created a Table ctl typedef with 60 rows for viewing some data. I am calling this typedef in another Vi and have used the CellBGColor property to grey out some cells marked with X. I checked with the highlight execution, and the greying is done only upto 39 rows, before it moves to the next column. Any ideas why this might be happening? Does the table.ctl have some sort of limit? Any help will be appreciated 🙂
Cheers,
mulayvus
Message 1 of 8
(3,967 Views)
I'm willing to bet that you are telling it to only set the BG color on rows up to 39.  Code will "typically" only do what you tell it to do.  Maybe your instructions aren't clear?  Smiley Wink
Can you post your code so we can help you?
aputman
Message 2 of 8
(3,965 Views)
Hi aputman,
actually should not be so as I am also telling it to count the rows... Anyways, you can find the logic in the attachment.
Cheers,
mulayvus
Message 3 of 8
(3,923 Views)
Accepted by topic author mulayvus
Hi mulayvus,
did you read the help for those "NumCols" and "NumRows" properties?
Maybe you only read the visible rows/columns!?
The size of your array is defined by the string array displayed in the table!
Message 4 of 8
(3,919 Views)
The property node that you are using outputs the number of rows/columns which are visible on the front panel.
Are you displaying all 60 rows at one time or do you using the scrollbar to move the rows?
Rhys
Message 5 of 8
(3,917 Views)
I am using a scrollbar. So how does this work? I do not want to resize the table. I tried to run the VI with the second half of the table visible, but the counting begins with the first row.
mulayvus
Message 6 of 8
(3,908 Views)
Hi mulayvus,
as said before: get the size of the 2D string array you are wiring to the table!
Message 7 of 8
(3,905 Views)
since I had to grey out the cells only once, I resized the table, ran the program and resized it back again.. Worked! Thanx for all your inputs! 🙂
Cheers,
mulayvus
Message 8 of 8
(3,898 Views)
