Table Reference Global Variable
Inorder to update a table in One VI from another VI, i need a Global Variable Reference of that Particular Table. How  shall i create it.
Anybody please comment on this.
regards,
mfp.
(4,596 Views)
You can use LV2G,
an example is attached, you may work on same lines.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,587 Views)
Thanks for the reply.
But i want to use a Global Variable to get the Reference of the table in the updating VI.
what shall i do for that?
regards,
mfp.
(4,582 Views)
Create a 'Global Variable', place a 'Table' refnum control on the front panel of variable.
Check the attached example of global variable with 'Table' refnum.
(4,576 Views)
Thanks for the support.
Since my table is a MCL, Shall i use the attached VI?
regards,
mfp.
(4,559 Views)
