Table Control Byte Array
Hello all,
I'm a new user to this forum. My question is can a table work with controls and indicators?  I'm trying to read data from a serial port and store it in a table. I also want to be able to change data within the table.
(3,336 Views)
The attachment is a example of what I want the table to look like. I want the "Voltages" to be what i guess is indicators, and the Relay & Current to a control, any suggestions would be appreciated
(3,335 Views)
Its possible, but not a good idea - keep control and indicator tables seperate.
CLA | CTD
NI Alliance Partner
iLV Test Solutions Ltd
(3,304 Views)
There's no simple way to disable certain columns in a table control, so if the user can edit one cell they can edit any cell. However, you can use a table indicator and place controls on top of it to give the appearance of having some editable cells in a table and others that are only for display.
I posted a screenshot and sample code here: http://forums.ni.com/t5/LabVIEW/array-of-cluster/m-p/1822423#M625025
(3,275 Views)
