Tab control name editing
In my application i am using tab control .
For that i want to programatically change tab names and i want to enable and disable a specific tab .
In property i cant find this option and in discussion forums i could not able to open the vi mentioned in the link
What might be the problem .
Thank you
Raja
(4,443 Views)
I don't think you can enable/disable a page, but you can disable all of the controls on a page.
Jim
(4,438 Views)
To enable disable a tab page:
Ben64
(4,433 Views)
Accepted by topic author Nagaa
So, adding Ben64's answer, we have:
Jim
(4,424 Views)
Thank you very much
ben64   and   jcarmody
(4,405 Views)
You are have your answer concerning enabling and disabling tabs. Concerning the first part of your question you can not dynamically change the names of tabs at runtime. The reason is that logically tabs are enumerated with the tab names being the enumerations. In other words the names aren't properties that you can change, they are part of the datatype.
Now what you can do is use a combination of buttons and enabling/disabling controls to simulate the appearance of a tab control - which might not be a bad idea given the problems that tabs can cause.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,394 Views)
