Tab control list mode in vertical direction
How did you assign the desired images at each panel ?
Cedric
Message 11 of 13
(1,734 Views)
Right click on the tab and select Advanced >> Tab Layout >> Image Only (or Image - Text)
Copy your target image from a viewer to clipboard (for example, with LabVIEW itself by drag and drop from Windows Explorer to the VI front panel then Ctrl+X to set in clipboard)
Right click on the target tab and select Advanced >> Tab Layout >> Import Image from Clipboard
(To remove, same action, by selecting Remove Image from Tab)
Message 12 of 13
(1,725 Views)
If you really want tabs on the side and horizontal text i guess you'll have to add the text as pictures on the tabs.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(1,721 Views)
