Tab Order
I have a tab control on the front panel of a vi. I also have numerous string/numeric/boolean controls on each tab. When running the VI, the tab order (this is the keyboard tab key now) is incorrect for the various controls on each Tab. However, choosing Edit-Set Tabbing Order, does not allow the ability to assign the controls on each tab to a number. Only the actual tab control itself. Sorry if this is confusing. Thanks for any suggestions here.
(2,992 Views)
Right click on the tab(the actual tab where the tabname appears, not the inside of the page. If you have the tab invisible then you need show it, you can hide the tab later) , at the very bottom there is "Reorder controls in page".
Joe Y. Guo
Roush Industries, Inc
(2,992 Views)
