Tab Control
Can i run vis in tab control with out using sub panel?
(3,555 Views)
Hi Jawad,
I'm afraid that if you want sub vi's panels to appear in the tab controls then you must use the sub panels container.  Is there any reason why you did not want to use these?  If you need more help then please let me know what it is you are trying to do and I may be able to suggest an alternative method for you.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,527 Views)
Hi James,
I am using Field point 2010 and it doesnot support sub panels and now it want to use tab control instead of sub panel. I want to know is there any possible way that i can open vi in tab control.
(3,500 Views)
Hi jawad
I could not understand what you trying to say, when u said FP 2010 does not support Sub PanelSmiley Surprised ?????
FP 2010 is a RT Controller & you can read the data from modules connected to FP 2010, but how u want to use a Sub Panel or Tab Control ?????
Rajan
Thanks & Regards,
Rajan
(3,488 Views)
Hi Jawad,
I presume that you want these windows for debug?  Real Time itself has no user interface, this is why you cannot use subpanels, but if you are running the VIs from a project on the controller LabVIEW does some communication behind the scenes so that you can debug using the the front panels.  If this is what you are doing then if you open the SubVIs front panels on your Windows PC when running on the target you should see the execution of these as well.
James Mc
(3,475 Views)
Hi James,
Thanx for help and guidence
(3,467 Views)
