TPC2006 keyboard doesn't appear
Hello
I have two questions,
1. I'm workin with TCP2006 and I'm trying to open the keyboard but it's doesn't appear. I did everything the manual said but it wasn't succesfull.... I suppose that tha keyboard is out of the panel, if so how can I see it in the panel again?
2. I was wondering if I can read data from a USB6009 using TPC2006.... is it possible that?
Thanks a lot
FLAVIO CARRILLO
(2,580 Views)
First question:
In the manual, is showed that the soft keyboard can be found in a small icon that appears in the status bar? Did you check this status bar? Could you please describe better this issue?
Second question:
I'm sending to you a link from a forum that is discussing this question:
http://forums.ni.com/ni/board/message?board.id=170&message.id=273383&requireLogin=False
Please contact me if you have any doubt.
Best Regards
Luciano Borges
National Instruments Brazil
Luciano Borges
Test Development Engineer
(2,504 Views)
