TPC 2206
Hello. I have to buy a TPC 2206.
Should I buy with Windows XP Embedded (XPe) OR Windows Embedded Standard 7??
I go to buy this:
781848-01 6" Industrial TPC w/ WES7 and LabVIEW TPM Deployment License
I have LabVIEW 2014 (with DSC and RT module) but I need to know if I will be able to program  this TPC with LabVIEW 2011 too (with DSC and RT module) . (I would have to be able to program the computer with both options).
Thanks!
(3,485 Views)
Hi CracKatoA
On the TPC 2206, in order to develop, run, debug, and deploy LabVIEW VIs on National Instruments hardware running the Windows Embedded Standard operating system you would have to install the LabVIEW Remote Development Target Support, however the first version for that software was the 13.0 and on the software readme file you would have as a requirement that the Run-Time Engine version must match the LabVIEW development version on both target and host.
So with that information I would say that you would have to most likely work with the 2014 development machine and the LabVIEW 2014 Remote Development Target Support
Hope that you could find this helpful !
Sil.VI
(3,407 Views)
