TO rotate a shaft
Thanks again for your response.
This is what i posted alreay//In my project i am using CRIO 9073 with NI9237,9401 and 9505.
With this setup,i gotta rotate a shaft connected to it. With my code,i am able to rotate the shaft,control the drive direction but i would like to control the PWM as well.//
The AI is from the Force transducers---I think this should be triggered right when the motor rotates.
There is an Encoder which has Phase A,B and Index outputs.I tried tapping these but i see the index always stays zero.It must increment by 1 for each rotation.
I basically want PWM,DUty Cycle,Encoder,POsition controller,DAQ loops...With these,a closed loop with the shaft and the motor is achieved.
Message 11 of 15
(1,412 Views)
Hello krupa,
if you want to detect the index or the A or B line you have to implement this on the FPGA in a way like this (not tested)
best regards
Alexander
Message 12 of 15
(1,406 Views)
Sure,i will test this.Can i send you a PM pls??
Message 13 of 15
(1,404 Views)
Hello krupa,
yes.
best regards
Alexander
Message 14 of 15
(1,400 Views)
latest code attached
Message 15 of 15
(1,394 Views)
