TNT5002 GPIB
I am using TNT5002  to implement GPIB GEN4882 mode communication. The product will go to EMI test. When the END_RECEIVED bit is set, and it will go to GPIB FIFO to read the data. Then talk addressed will be set. Due to the EMI interfere, the count from CNT0 is reset to zero. In this scenario I want to reset state machine and let state machine go to Listen state instead TALK addressed Being set. Can anyone knows how to do it?
Thank you for your help.
Lillian
(2,946 Views)
Lillian,
Unless I’m misunderstanding your application, could you clarify that your issue is from EMI interface in hardware. Since this is the LabVIEW discussion forum, there might not be as much activity for low level hardware and you might want to post in Instrument Control.
If you have questions about how to design state machine architecture, then there are examples and clarification that the community can give.
Ali S.
Application Engineer
Ali S.
Applications Engineering
(2,903 Views)
