THD calculation for ADC
Hello all,
I'm trying to calculate THD(total harmonic distorsion) parameter of an ADC, the point is that i must calculate the FFt
in order to get THD without using any of the labview VIs (FFt and Vrms VIs) i've made the VI
joined below(i used some vis found on NI forums), the problem is that i still don't have an idea how to replace Vrms vi with math nodes.
If anyone could help me, i would be greatfull
NB:i'm using 2009 labview basic version
(3,017 Views)
Hi smiti,
you have been asking this in a different thread, so why don't you stick with your original one?
To replace the Vrms VI you could simply look into it to get it's internals. To replace the FFT vi is just silly...
(3,012 Views)
(2,990 Views)
You can try interfacing FFTW dll into labview.
The FFTW can be found at http://www.fftw.org/install/windows.html
Interfacing to dlls in LabVIEW is discussed here: https://www.ni.com/docs/en-US/bundle/370109b/resource/370109b.pdf
When you have FFT result, arriving at various Vrms values should be a breeze through.
Good Luck!
(2,986 Views)
