TDS oscilloscope
Hi
I am using the TDS oscilloscope,Just using the LabVIEW program to download the waveform from the scope.
Now i am interested to know little bit more, for example if we are measuring a Peak-Peak value,how could we read it in the labVIEW program.
Pls help me
Message 1 of 16
(4,468 Views)
Hai,
Search the forum by 'measuring peak to peak' and you can get lot of ideas.
Post further if any other specific help required.
Mathan
Message 2 of 16
(4,462 Views)
continue here
Message 3 of 16
(4,448 Views)
Hi vrk,
1. Are you using VIs provided by Tektronix, or writing your own?
2. Are you looking to get the measurement value calculated by the 'scope, or calculate it for yourself?
Jim
LV 2020
Message 4 of 16
(4,432 Views)
Hi Imtis
I am using my own VI and I need to take the value measured by scope( for ex: peak to peak).
Message 5 of 16
(4,415 Views)
Your question has already been answered in the other post that mathan linked to.
Message 6 of 16
(4,409 Views)
Hi
I have developed a code,its function is to acquire the signal from the oscilloscope and display the Peak to peak value.Everything works fine.But in that i need to include a start  button,means when start is pressed it should start analysing the signal in the scope and give the value,then after sometime may be 10 seconds the program should stop.pls help with this
Message 7 of 16
(4,384 Views)
Hai,
Is this what u want?
Mathan
Message 8 of 16
(4,367 Views)
Thanks Mathan
It seems not working
Message 9 of 16
(4,363 Views)
Dear vrk,
Don't simply say its not working. It won't help any of us.
Post what happened after running that. Any error ? crash? what's the problem?
Mathan
Message 10 of 16
(4,358 Views)
