TDMS file like a .wav file
hi,
i would like to do a triggered acquisition of dynamic power spectrum and to save it in a TDMS file.
(XP pro, Labview 8.5, PXI 5600 and PXI 5620)
And then, when i read it, i will have the same dynamic power spectrum.
My problem is my "read signal" is static, and not dynamic like a ".wave" file for instance.
is it possible to do this?
find the 2 attached Vi
Thanks in advance
Seb_MDI
France
(3,678 Views)
Accepted by topic author seb_MDI
Not sure I understand what you mean by static versus dynamic files.
What you're doing right now is that you append all your spectrums to one channel in the file, so when you read the whole thing, you'll get one waveform with all the concatenated spectrums in it. Instead, you could use a different channel name every time you store a spectrum. That way, you could also attach related properties (e.g. time stamp, f0, df) to the channel.
You can then wire either a single channel name or an array of channel names to TDMS Read in order to retrieve the spectrums you want to look at.
Herbert
(3,657 Views)
Thanks for your response.
I have my TDMS file with my initial waveform power spectrum, i can write and read this power spectrum. Now, i would like to regenerate it with PXI 5421 and PXI 5610, is it possible?
is it with the NI-RFSG library ?
thanks
Seb_MDI
France
(3,623 Views)
