TDMS Write Memory and VI based API for TDMS - LV2009
Back in June I posted a question about a memory issue with TDMS Write (LV86). - TDMS Write Memory Leak
  • Does TDMS Write Memory work the same way in LV 2009? Does LabVIEW create an ever expanding buffer to hold indexes with each write?
  • What format do the VI-Based API for Writing TDMS Files write in LV2009? 1.0 or 2.0?
(3,606 Views)
Accepted by topic author Gleichman
  • For "TDMS Write Memory", it has the same behavior in LV 2009.
  • For VI-Based API, the file format in 2009 is 1.0, but 1.0 version files still work fine with LV 2009.
(3,571 Views)
In the future will it be possible to turn this "feature" off?
I guess that this is good - no compatability issues, but will I be able to use TDMS 2.0 in the future without the indexing issue?
Message Edited by Gleichman on 08-24-2009 04:15 PM
(3,550 Views)
Yes, we'll consider your request in the future. I guess you'll not wait for too long time 🙂
(3,522 Views)
If you have a product suggestion please post it to the LabVIEW Idea Exchange
(3,501 Views)
I've posted to the ideas exchange.
Disable TDMS Indexing Idea
If you use TDMS files to store periodic data, please view and comment on this idea. Smiley Happy
(3,493 Views)
