TDM-Excel-Add-In controlled by vba
Hello
We've got an application that generates many TDMS-Files. Now I have to import these files to Excel.
I use the TDM-AddIn and this works fine when I do the import manually.
But I'd like to automate the import using VBA.
I tried the trick with "SendKey" (see http://forums.ni.com/ni/board/message?board.id=60&message.id=5441&query.id=12678#M5441)
but this works (on my systems) only with Excel 2003. Unfortunatelly it has to work with Excel 2007 as well.
Has anyone an idea in this direction?
Many thanks
Raffael
(3,010 Views)
Hi Raffael,
your question is very interesting. I used my contacts and asked at R&D for DIAdem in Aachen for any informations on this. They told me that there is a new version of the Excel-Add-In planned for release in nearly 2 weeks. This means you should wait a little bit and then you can use a new API with several features like VBA-Programming and also something like controlling the Excel-Add-In from DIAdem-Script.
I gave the link you posted in this forum, to the developers and they will reply there as soon the release is finished.
Best regards
Alexander Rudolph
NI Switzerland
(2,982 Views)
Hi Alexander
Many thanks for your help! It's a pleasure that you used your contacts to help me.
So I'm looking forward to this new release.
Best regards
Raffael
(2,965 Views)
