TDM Deployment File Errors
I have devolped and application in LV 8.02 using TDM Express Storage vi's on a window XP Machine. I deployed this application to a stand alone 2000 Machine and I recieve error  "-2564  Open Storage". I have included all runtime engines and drivers with the package and yet the same message. This application works fine on the development system do I need plugins for target to use this file format?
(3,061 Views)
Greetings!
    You are missing the NI USI installer that is required to run the storage VIs. Please refer to the attachment for more information. The information is found from the LabVIEW help by searching for USI installer. Please let me know if this helps.
Thanks much
Avi Harjani
(3,045 Views)
Worked Thanx.
(3,034 Views)
