TCP
Hello
I have a problem with TCP (LabVIEW 4.0.1).
I have two computers in network.
I read data from board AT-MIO-16-L9 [computer 1], while a
TCP Listen listens for a connection.
I have a program on computer 2 (Simple data client.vi),
it uses TCP Open Connection to initiate a connection, then reads the
incoming data, and plots it on a chart.
When I stopped Simple data client.vi and start again I cannot
make connection. Is it possible ?
thanx in advance
best regards
Greg
(4,909 Views)
Hi
To establish a TCP connection with a remote port, a 'TCP Create Listener' followed by a 'TCP Wait on TCP Listener' can be used. However, if the connection is closed with a 'TCP Close Connection', a new connection cannot be established with the same port unless Labview is closed down.
If you would have had a more recent version of labVIEW, there's an example on the web that allows to reconnect to a TCP connection without closing LabVIEW.
I'm still giving you the links:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/8e52fb6a9c13a4e38625670d005b16c1?OpenDocument
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/c0888cf95e6c19c88625694c0076bde5?OpenDocument
Cyril Bouton
Nation
al Instruments.
Cyril Bouton
Active LabVIEW Developper
(4,911 Views)
[cut]
Thank you very much.
When a connection is established I can read and write data (1D-array)
to the remote application Can I write and read 2D-array ?
best regards,
Greg
(4,908 Views)
Greg,
Instead of reinventing the wheel here I'm just giving you a link to another discussion that gives a lot of tips on how to do that.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000CB2A0000&ECategory=LabVIEW.LabVIEW+General
Cyril Bouton
Cyril Bouton
(4,908 Views)
Hello , i have problems with the conection between my PC and IGW/400 CAN via WLAN.
I dont even know where exactly the problem is? may the problem is the configuration of the IGW/400-CAn or by my tcp.vi.
I try to connect the the IP and port if IGW/400 with the tcp conector, but unfortunatly it dose  not work.
Maybe some body know about this problem.
Anyway best regards and thanx in advance
Kami
(4,659 Views)
Kami
(4,656 Views)
