TCP
Hello everyone
I am trying to make a tcp server and client. I want when the client is shut off. all lights in the server can also be turned off. The program is OK the first time i shut down the client except the delay. it also work fine when i start the client again.But when i shut down the client again. the lights are not turned off.
i put the vi in the attachment.
Thank you so much.
(2,445 Views)
Why are your TCP Opens in the loops?  You are continually reopening them, but only close the final reference once the loops stop.
I think you should go back and look at the client and server LabVIEW examples again.
(2,319 Views)
