TCP connection does not work as EXE
The problem is in the RT exe.
This example used is as simple as you can get.
Message 11 of 23
(2,348 Views)
Again, are you certain that you are properly deploying the RT executable?  What are the steps you are taking?  Once you've built the executable, it must be set as startup and deployed.  Have you confirmed that the RT executable is running?  Have you tried remote debugging?  You can enable debugging in the build specification, then connect to the compiled application remotely and use the standard debugging tools to see whether it's running and generating an error.
Message 12 of 23
(2,347 Views)
Well, short story is that its now working.
Long story:
I used the RT Terminal COM 4 to make sure that the program was always running, and it was
I took out code to make the problem easier to handle.
Replaced a control (for the Port to Listen to) to the TCP Listen vi
Removed all other inputs to the same vi
Got better
The final solution was to NOT have the Err In wired. The property node (Value) Err Out was causing my problem.Probably because the Err In for the Property Node was unwired.
Thanks to all for your support.
Message 13 of 23
(2,320 Views)
The problem is not that the error input to the property node was unwired - that will not generate an error.  The problem is the property node is generating an error when used in a compiled executable on an RT target, because most property nodes require access to the front panel and an RT executable doesn't have a front panel (with the possible exception of the case where a remote front panel is connected).  Note that the property node will not work under RT, so if you're relying on that, your code will not function as expected.  Consider using a local variable instead.
Message 14 of 23
(2,315 Views)
I feel you wrote this in an earlier reply? Oh wait, you did. This is kind of like when I say to someone "nice to meet you I'm Greg" but then stop listening as soon as I introduce myself and I don't hear their name.
Message 15 of 23
(2,305 Views)
Look, it took me a long time to get to 2000 posts.  How am I going to get to 5000 if I don't repeat myself occasionally? 😉
This does seem like a good opportunity to plug one of my ideas on the Idea Exchange: Warn about front-panel property node use when building RT application
Message 16 of 23
(2,299 Views)
All,
I went back this morning and added the Prop Node Err Out back to the TCP Listen Err In and the TCP connection was refused.
Took out the Err link and it worked again.
The prop value was the value to an indicator that I want to clear at the start of the program (for debugging). It was attached to the TCP Listen, only to keep it from going anywhere it wanted when I do a sweep of the diagram.
Thanks to all and I learned a little bit more.
Message 17 of 23
(2,286 Views)
Pls change the RT application as TCP listen and GUI(Host) as TCP Open.
U didn't give the code. but i attached the basic module.
try it
Message 18 of 23
(2,283 Views)
Will this method reestablish communication if the Host stop then restarts? (With the RT always running)
Message 19 of 23
(2,275 Views)
HAHA! I wasn't knocking you though with that comment. It's all too often on these forums I see soemone ask a question then not try the suggestions in the responses!
And your idea has another kudo now! I thought I had kudo'd it before, but I guess not!
Message 20 of 23
(2,266 Views)
