TCP Read Error Code 1
I met a problem in using "TCP Read" in LabView;
First I use "TCP Open Connection" building connection successful with a instrument; and seem the connection ID as the global,equal to a "TCP Network Connection Refnum";
Then I use the global as the connection ID,and use "TCP Write" send a command to a instrument;and use "TCP Read" Receive the instrument return message;this time a 56 error occurs,it is normal.
But after I use this method Send/Receive two times successfully,when i use "TCP Read" receive message, the error 1 occurs,and nothing received.
In each TCP operation,use the global "TCP Network Connection Refnum" as the "Connection ID" input.
someone can tell me,why does it occur?
(6,454 Views)
If I'm not mistaken error 1 is invalid input. Is it possible your global variable changes somewhere during the way or that you're using the close TCP VI somewhere? Try using a probe to see if the read VI recieves the proper connection ID and if that doesn't help, try making a small test VI which will run without globals. This will help you narrow down the problem.
___________________
Try to take over the world!
(6,445 Views)
JiangYu wrote:
> I met a problem in using "TCP Read" in LabView;<br>First I use
> Connection Refnum";<br><br>Then I use the global as the connection ID,
> normal.<br><br>But after I use this method Send/Receive two times successfully,
> as the "Connection ID" input.<br><br>someone can tell me,why does it occur?
Ouch, globals! That is usually the first sign of a bad application design.
For the rest just watch out. LabVIEW refnums are garbage collected
whenever the VI hierarchy which opened them goes idle (stops executing).
So Executing a VI which Opens the TCP refnum and writes it into a global
and then quits and then executing another VI which tries to use that
refnum from the global will simply fail with error 1 as the refnum has
been already automagically closed and is therefore invalid.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(6,434 Views)
