TCP Open Connection timeouts too soon
Hello to all LabVIEW users!
I have noticed that using TCP Open Connection function is not following timeout value.
Check the image. The time difference is 21 seconds, despite setting timeout to 60 seconds.
Anybody noticed this before?
LabVIEW 18.0.1f4 (32-bit)
(3,528 Views)
Accepted by topic author AdamTrojak
From the Detailed Help of "TCP Open Connection Function":
TCP Open Connection Details
When wiring an unused IP address, you may receive an error stating the network operation exceeded the user-specified or system time limit. This error occurs before the default timeout of 60000 ms has occurred. To correct this error, wire an IP address that is running and listening on the port you are trying to use.
Could this be the problem you are having?
(3,517 Views)
Yeah, this might be it. It is troublesome because I am timeouting before device boots up, so for the booting time it looks like "unused IP address".
Anyway, thanks for help!
(3,501 Views)
It doesn't have to be a problem.  You could use this error to figure out if your device boot up.
Bill
CLD
(Mid-Level minion.)
(3,494 Views)
I do some LabVIEW Real-Time work, where I need to connect to a "remote host" (which I call a "Target", with the PC running the main UI code being the "Host").  I wrote a little routine called "Target ID, IP" that does the following:
  1. Calls "Find Systems (VI)", which is installed with NI System Configuration.  The function can be found on the System Configuration sub-Palette of the Measurement I/O Palette.  I usually use the "Only if Online" setting, otherwise it returns "formerly connected" systems that MAX might have cached.
  2. This returns an array of Strings, which might be an empty array of nothing can be found.
  3. In my case, if no IP is returned, I force a default IP.  Probably in your case, you should pop up a message saying "Nothing found -- should I try again?".  Take appropriate action if the User answers "No".
  4. If one IP is returned, I parse the string to get the IP in the format "XXX-YYY-ZZZ-WWW" and use it.
  5. If more than one IP is returned, I pop up a Dialog Box that asks the User to choose a Target from the list of IPs returned.
Doing something like this can handle the problem of timing out before the remote device boots up.
(3,461 Views)
