TCP/IP
I am using a TCP/IP connection to communcate between executables. The communication is not constant, but it may occur every 10 seconds or in some situations it may occur every 1 second. The communication between the executables can be summed up like this:
1. The server is listening for connections.
2. The client opens a connection sends a command and possible some data to the server.
3. The server responds to the client to complete the communcation, possibly with some data but not nececarilly.
So I am unsure about whether I should close this connection after step 3, or should I keep it alive and have the server constatly reading until the next command and data is sent from client. Or should I close the connection and then just listen for a new client initiated connection again. Thanks for the help Smiley Happy
Anthony
(3,284 Views)
I recommend that you keep the connection open.  You may want to move the TCP handling into a separate loop (if it's not there already) and then whenever data is received, put it into a queue where it can be handled by the rest of your code.  Creating a new connection every time you want to send some data in either direction is not very efficient.
(3,275 Views)
Okay, that makes sense. Thanks
(3,265 Views)
Yes, keep it open but you may want to add some code to re-connect if the connection is lost.
(3,237 Views)
