TCP/IP used in a re-entrant vi.
How can I use a vi in a loop that contains TCPIP vi's(listener nand etc.) and will not lock up the next time it is called ?
Engineering Services
Teledyne Relays
(2,740 Views)
I think the problem you are having is a timing one, all TCP/IP vi's have a timeout option, if you set it to -1, the vi will wait forever until it completes (read, write, listen...), by default, listen has a forever wait, read and write 25 seconds, you could reduce this or be sure the action occurs in a short amount of time. If you set this time to 0, the vi won't wait, but will return an error if action is not ready to be completed. If you give more info of what are you trying to do, someone could help you.
Hope this helps
(2,739 Views)
You could have problems if you are opening and closing the TCP/IP session
every time you execute the loop. Opening the refnum once and re-using it by
storing it in a shift register can help prevent resources running out in
Windows .
Hope that is your problem and solution..
"Mal G." wrote in message
news:506500000008000000421C0000-986697009000@quiq.com...
(2,739 Views)
