TCP IP multi client connection is not working properly
You're right. But the problem that causes in my server is the race condition when I try to use an other Queue to get the command coming from the client( second loop) and Dequeue it in the Top loop. Because the top loop originally is Enqueueing data for the second loop to grab. by Implementing an other queue, It will not Enqueue anything since It'll be waiting for the data from the second loop to dequeue
Message 11 of 31
(1,993 Views)
Notifiers can be used.
And don't forget about timeouts.
Message 12 of 31
(1,989 Views)
tried it.. It didnt work either
Message 13 of 31
(1,980 Views)
Did you look at timeouts.
I'm not saying you can't use globals.  Just that they are more known for causing race conditions.  It is even more likely someone will use them incorrectly then using a queue incorrectly.
If you are careful and know what you are doing, they can be effective.
Message 14 of 31
(1,969 Views)
I tried Using Both Queue and notifier, the timeouts avoid the race conditions but the Enqueue or send notification vis give me error 1. Saying an input parameter is invalid. I check my data type and data being sent, they are all the same.
Message 15 of 31
(1,950 Views)
I'd have to see the latest version of your code before I could figure that out.
Message 16 of 31
(1,940 Views)
My apologies. Here's the latest version
Admin Note - VIs removed per user's request.
Message 17 of 31
(1,934 Views)
@RavensFan, did you get my latest update?
Message 18 of 31
(1,909 Views)
It looks like the same files as before.  It still has all of those awkward queue manipulations.
Message 19 of 31
(1,904 Views)
MY apologies. Here's the latest
Message 20 of 31
(1,897 Views)
