TCP/IP decode c++
Hi steffi
i add an client/server example for you. i don´t know why you need a timeout on the TCP.read.vi because if the client close the connection, then an error will occur at the read.vi so that you can react on it. After the connection has closed by the client the server wait for a new connection.
Hope it helps.
Mike
Message Edited by MikeS81 on 02-06-2008 09:39 AM
Message 31 of 39
(1,652 Views)
Hi Mike,
thank you very much for your help! Unfortunately I only have LV 7.1, should have told you before, sorry! But I think I know what you mean and I changed it that way AND it works: ) So, for me it's perfect! Thanks a lot!
Steffi
Message 32 of 39
(1,649 Views)
Ok, I think I understand your problem now. The next thing you have to do is:
Unbundle your Error cluster after reading TCP/IP, than compare the error code with the constant error code if client closes connection. If the comparision is true, than you have to exit the inner loop. So connect the output of comparison to the Loop Condition of the inner loop.
Message 33 of 39
(1,646 Views)
hi steffi
i´m sorry i forgot it. see my attached picture for the server.
Mike
Message 34 of 39
(1,644 Views)
OFFTOP
Mike, Steffi are you germans?
Message 35 of 39
(1,639 Views)
Thanks to you both it works perfect! : )
Message 36 of 39
(1,637 Views)
yes i am
Mike
Message 37 of 39
(1,635 Views)
Yes, I am Eugen. I know my English is bad; )
Message 38 of 39
(1,633 Views)
My english is bad too. Take a look on my tutorial and forum. There you can speak german.
Message 39 of 39
(1,627 Views)
