TCP/IP Client RFID Reader
I can open a TCP / IP connection to the reader via TCP / IP client. The client sends a simple hex command. The transmission protocol is also correct (tested with Microsoft Network Monitor).
How can you control the reception? Do I need a server or the server is a Reader? Reception Protocol payload is always 0 bytes. Does not work the command?
(4,496 Views)
There's a TCP server example available. Help>>Find Examples>>search "TCP". Data server.vi is a good example.
(4,485 Views)
I have seena all examples. Is my device (Reader) not the server? Need I a Server.vi ?
(4,474 Views)
That would depend on your device configuration I think. The manual for the reader should tell you how to interface to the device. My suspicion is that the reader is a server but it could work either way. Wire Warrior
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(4,444 Views)
