TCP Halts on both NICs if DHCP goes offline
cFP-2220s running LVRT 2011 / Fieldpoint 6.0.9. do not seem to handle loss of contact with the DHCP server *after* bootup.
I have the "Halt on TCP failure"-settings unchecked, and, if the DHCP server is offline when the controller boots, it behaves fine; it starts the RT-application.
However, if the DHCP server is online when the controller boots - but later goes offline, things get messy. Instantly the controller becomes unresponsive on the primary ethernet port. The secondary ethernet port will continue to serve active TCP/IP sessions, but only until these are closed; it will be unresponsive to new connections. This frozen state lasts until the DHCP server on the port 1 network comes back on - then both port 1 and port 2 function again.
One might argue that halting things on port 1 is reasonable (but not practical...), but port 2 is using static IPs (only mode it supports) and should not be affected at all. Loss of communication there just because port 1 lost contact with the DHCP server?? Is that the intended behaviour? Is there a way around it?
(2,683 Views)
Out of curiousity, is your DHCP server providing other services (I'm thinking DNS in particular) as well?
(2,676 Views)
The DNS goes offline too yes, and the gateway.
The TCP listeners are set to *not* resolve the address, so it should not hang on DNS lookups ((the RT application serves modbus connections on port 502 and a proprietary protocol on port 64000) .
The lack of gateway should not be an issue either as the incoming connections originate from the local subnets of each port.
(2,661 Views)
The DNS comment pointed me in the right direction.
One of the TCP/IP based server interfaces in my application ran an IP to name function. This would then freeze that server on both ports...AND - unexpectedly - freeze all current sessions on other TCP/IP ports as well.
Should not RT be designed to behave more robustly? A loss of DNS on port 1 should not affect traffic on port 2, regardsless of the use of address resolution? I guess it's handled at different levels though so isolating NIC2 might be difficult?
(2,652 Views)
