TABLE SCROLLBAR OPTION
I'm creating a table with too many columns to bee simultaneously visualized on the screen, so I must insert an horizontal scroollbar, but I'd like to fix the first column while the scrollbar is moved for a more comprensible visualization of the table data.
How can I solve this problem?
Message 1 of 10
(4,702 Views)
Hi Mattia,
Here is a solution.
But i must admit that even through it does the job, it is not very convincing
I have put a smaller table embedded inside the main table.
The first Column is indexed out and shown on the smaller table.
So can anyone think of a better trick?
Regards
Dev
Message Edited by devchander on 12-30-2005 05:51 AM
Message 2 of 10
(4,687 Views)
Thank you devchender,
but your solution is good only if the table has not the vertical scrollbar: in fact if you have a vertical scrollbar, when you move it, only the rows of the main table scroll down.
Message 3 of 10
(4,681 Views)
Make the row headers visible (right click>>Visible Items) and it will do what you want. The header index is -1, in case you will need it.
___________________
Try to take over the world!
Message 4 of 10
(4,676 Views)
Thank you TST,
I think it's a good idea, but I don't know how insert my variables into the column headers.
Can you explain me with an exemple?
Message 5 of 10
(4,672 Views)
This is a problem adressed in ListVIEW. I used two tables, dynamically associated.
Chilly Charly    (aka CC)
Message 6 of 10
(4,673 Views)
Charly, no need for the ListVIEW solution (which is what Dev suggested), since it's only one column.
I can't give you an example, since I'm not near a computer with LV at the moment, but, as I said, the index is -1, so you can use the array VIs to insert or replace the headers by using that index. If I remember correctly, there are also header properties which would be 1D arrays of string.
___________________
Message 7 of 10
(4,671 Views)
tst
I missed the solution you proposed, because the post behind was refering to the column headers.
Here is a translation of your idea...
Message Edité par chilly charly le 12-30-2005 04:11 PM
Message 8 of 10
(4,660 Views)
Hi Mattia,
Hope you have no row header to display in your table.
If you do not, then the latest solution proposed ( one  CC has posted ) is the best option.
Regards
Dev
Message 9 of 10
(4,635 Views)
Of course, I have no headers so I'll use this solution that is very good, thanks.
Happy new year!
Message 10 of 10
(4,631 Views)
