TAB in ActiveX container does not work
Labview overrules the TAB button if you are using an ActiveX component on a front panel. Does anyone know if it is possible to use the tab button in the IE ActiveX component?
I’ve found several topics about this subject, but all without a solution. Maybe there is is a workaround at this moment?
http://forums.ni.com/ni/board/message?board.id=170&message.id=148876&query.id=38847#M148876
Kind Regards,
Jonas Van Otterdijk
www.cit.be
(2,731 Views)
Greetings Jonas,
There is no clear cut solution for tabbing inside an ActiveX component. The link below will guide you to an article that might provide with more information and another possible workaround.
http://digital.ni.com/public.nsf/websearch/533F68C568A2B575862570A600747462?OpenDocument
Wouter
NI Belgium
(2,705 Views)
