System time in Write TO Measurement File
where in the front panol I should change?
It is not clear to me in the thread.
thanks
wei shen
Message 11 of 17
(1,270 Views)
There is no place on the front panel you should change. I don't understand where you got that idea. The suggestion was to replace the Write to Measurement File with Export Waveforms to Spreadsheet File. That is block diagram work.
Message 12 of 17
(1,263 Views)
But, I constantly got an error here.
Would you know what is the cause?
wei shen
Message 13 of 17
(1,255 Views)
Thats not an error. It's just aking you if you want to replace the file. If you want to append, you need to specify that.
Note that the export waveforms is not a direct replacement. You may have to do some additional progamming that the Express VI was doing for you.
Message 14 of 17
(1,252 Views)
Got it.
Yet, I did not find the option for formating the output time format.
Here is my code. Would you take a look at it?
wei shen
Message 15 of 17
(1,228 Views)
There is no option to change the format of the date/time stamp. You would have look on the block diagram to see how it's formatted. I don't know if there is a windows setting that it follows.
Message 16 of 17
(1,221 Views)
The subVI called Waveform Time to Date Time String is what defines the format of the date string.  In there, it uses a function called Get Date/Time String to format the date and the time.  It is set to use the Short Date format as defined in your operating system.
If you want to use a different date format, then you need to either change it in your OS, or not use this subVI.  Create your own subVI that converts the timestamp to the date string.
As for the extra blank line, there is a CRLF being put into each line.  When it is written to the file up near the top of the VI, a True is wired to the Convert EOL to current platform.  I would try changing that to a False.  But first you might want to see what bytes are actually being put into the file, is it multiple carriage returns and line feeds, or just one of each.
Message 17 of 17
(1,216 Views)
