System requirements
hey,
I know that one of the requirements to install LABVIEW is Windows 7, is there a way or version that can be installed on Windows XP?
Best Regards,
Matan
(3,735 Views)
LabVIEW will 'work' on Windows XP. However, as far as I can see LabVIEW 2009 was the latest version officially supported by W-XP
 http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du/q/LabvIEW%202009/
(3,734 Views)
thank you i will try that !
(3,706 Views)
As Tom mentioned, the latest officially supported is 2009... but I've had LabVIEW 2013 installed and running in Windows XP without issues.  I suspect later versions will work as well, but haven't tried them personally.
(3,700 Views)
Accepted by topic author Matanlaza
According to the LabVIEW and Microsoft Windows Compatibility page LabVIEW 2015 SP1 is the last version to support Windows XP.
WARNING:  If you install LabVIEW 2016 or higher on the same machine and want to build an installer it will not work on Windows XP.
YES it effects ALL LabVIEW installations even versions compatible with Windows XP.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6seSAC&l=en-US
=== Engineer Ambiguously ===
(3,652 Views)
