System requirements for LV6i
Which are the minimum requirements for a PC system to support LabVIEW6i?
(3,117 Views)
See page 8 of the following document: http://www.ni.com/pdf/products/us/2msw70-76e.pdf
These are the specs for 6.1, but 6 is the same except half as much ram is required for 6 on Windows and Mac boxes.
Brian
(3,117 Views)
Have I understood well? I only need half the ram is required?
I want to install LV 6.0.1 on a PC with 48Mb RAM, Pentium 100, Windows 98
Will it work or does not worth to try it?
(3,117 Views)
According to the catalog it should work. 32MB minimum and 64 MB recommended for LV 6. It will probably be somewhat on the slow side, but should work. Good luck!
(3,117 Views)
I have LabVIEW 6.0.2 running on a 200 MHz AMD K6 with 48 Mb of RAM and Windows 95. It's not the fastest in the world but it lets me get some work done at home.
(3,117 Views)
