System monitor counter
I'm trying to use system monitor activeX in order to control memory usage and CPU usage of my PC.
All activeX properties work fine except the most useful: counter.
I've attached the screen shot of my VI.
P.S. I think counter property is used to read wich counter to read?!
Thank you,
Paolo.
Message 1 of 9
(6,785 Views)
You're probably referring to the "Counters" property, which is a collection of counters, as described in MSDN. To use this you can do something like this:
Note: You need to change the "Preferred Execution System" of the VI to "user interface" to get a VI that uses this ActiveX control to run. You can change this from the VI Properties (File->VI Properties, and then change to the "Execution" category). Interestingly enough, once the VI stops the control keeps running.
Message Edited by smercurio_fc on 05-02-2006 08:58 AM
Message 2 of 9
(6,781 Views)
Great! It's working!!! Smiley Happy
Thank you!!!!
Paolo.
Message 3 of 9
(6,757 Views)
Simply Superb !
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 9
(6,641 Views)
Great work smercurio !
Message 5 of 9
(6,633 Views)
Cool!  Anyone know the name of counter for memory usage?  How did you get the input reference to DISystemMonitor?
Yes I did go to MSDN, and after swimming in the links for awhile, I found some code for listing the counters... but wow, surely the typical name for a memory counter hasn't changed?
Thanks.
Message 6 of 9
(5,882 Views)
The input is the ActiveX container on the front panel. Attached is the actual VI (LV 8.2). I know it works in XP, but it doesn't work in Windows 7. At least Windows 7 64-bit. Not sure about Windows 7 32-bit.
The syntax for the pathname is \\Computer\PerfObject(ParentInstance/ObjectInstance#InstanceIndex)\Counter. In my example "PerfObject" is "Process(*)" to show all processes, and "Counter" is the name of the counter, which is "% Processor Time". You can get the various performance objects from this page: http://technet.microsoft.com/en-us/library/cc783073%28WS.10%29.aspx. Once you select one of the performance objects you want then the right-hand pane will list the available counter names. As you'll note for the Memory object, there's lots of memory counters.
Message 7 of 9
(5,873 Views)
Thanks!!!  This was interesting.  After trying various counters from Memory, TCP, Process, System, and Server, I couldn't find any which correlated with the "not enough memory" error associated with my TCP/IP connection.  Any ideas?  Do you think this is my Windows Message loop filling up?
Message 8 of 9
(5,833 Views)
That's a different question, and we should stick to the separate thread you created for this.
Message 9 of 9
(5,825 Views)
