System.Management.ManagementClass in .NET
I have been trying to convert the following to LV but am getting stuck...
System.Management.ManagementClass mc =
new
System.Management.ManagementClass("Win32_NetworkAdapterConfiguration");
ArrayList list = new ArrayList();
foreach ( System.Management.ManagementObject mo in mc.GetInstances() )
if ( ((bool)mo["IPEnabled"]) == true )
......>etc.
now - the examples use string based stuff, ManagementClass requires a "path"....
Any ideas?
Dav.e
(5,099 Views)
In the C# example, you automatically end up creating a temp ManagementPath object, since the ManagementPath object has a constructor that takes a string. But if you are using this from LabVIEW, you will need to first manually create the ManagementPath object, provide it the string you need, and then pass the reference of that Management object to the ManagementClass constructor.
I have attached an example of this.
So it wasnt using a LabVIEW path objet, but as the documentation specifies, it expects a ManagementPath object.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(5,099 Views)
in Dotnet is
Imports System.Management
Imports System.Management.ManagementClass
Imports System.Management.ManagementBaseObject
Imports System.Management.ManagementObjectCollection
Public Class Form1
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim mc As System.Management.ManagementClass
Dim mo As ManagementObject
mc = New ManagementClass("Win32_NetworkAdapterConfiguration")
Dim moc As ManagementObjectCollection = mc.GetInstances()
For Each mo In moc
If mo.Item("IPEnabled") = True Then
ListBox1.Items.Add("Endereço Físico : " & mo.Item("MacAddress").ToString())
End If
Next
End Sub
Notes: Listbox1 is better than textbox for create itens; GL .
(4,340 Views)
