System Identification Palette Missing
Hi. I have Labview 8.2 with Control Design and System ID. However, both palettes were missing on my system. Fortunately,  the fix is available for Control Design on NI website but I didn't see it for System ID. Is there a fix for Sytem ID as well?
(3,070 Views)
Did you originally install the Control Design and System ID toolkits before upgrading to LabVIEW 8.2? The following KnowledgeBase article explains how to install a toolkit across multiple versions of LabVIEW:
What order did you install the toolkits / LabVIEW in? Did you install the toolkits before installing LabVIEW? I am sure that we can work together to resolve this issue. Have a great day!
Casey Weltzin
(3,054 Views)
What should the correct order of installation be like?
Thanks..
(2,898 Views)
Hi xf,
The proper order of install is to first install the oldest version of LabVIEW and then move forward in order.  Then you can follow the directions that are
in the knowledgebase that Casey Linked.
Message Edited by Adam_H on 12-12-2008 02:47 PM
Adam H
(2,876 Views)
