System Exec
Just like to know how can i going to close the application call by system exec??as i going to repeat again.
Attach the .vi
regards,
simon
(3,726 Views)
Hi Simon,
which application do you start? You can give this application the focus and send ALT+F4 to it or you destroy the process or the application has another gateway through which you can communicate with it.
Mike
(3,724 Views)
Hi Mike,
i going to call the batch file here. let say as this simple code. how can i close the dos application by using labview??
:Begin
cd\
mkdir c:\a
mkdir c:\b
mkdir c:\c
regards,
(3,718 Views)
Hi simon,
i´m not sure what you mean. If you call your batch file with the "cmd /c" command, then the box closes after it is ready. You can also connect a true to the "wait ..." input.
Hope it helps.
Mike
(3,714 Views)
Hi Mike,
My mistake here. Thanks for the help.
I able to close the application.
thanks and regards,
Simon
(3,711 Views)
Hi simon,
now i know what you mean and you don´t need to close something. See the attached picture. This works for me.
Mike
Message Edited by MikeS81 on 06-10-2008 08:32 AM
(3,707 Views)
