System Exec return codes
Not really on the Windows side! Your WTTServer executable calls some c runtime functions with invalid parameters causing the C runtime function to throw an exception. So while the exception is thrown in the C runtime library it's your server app that does something wrong.
The big difference between when you call that executable from the command line versus with SystemExec is most likley the current working directory. The command line shell always sets that to the directory in which you are at that moment inside it. In LabVIEW this is the current directory for the process, which is initially set to the directory where LabVIEW.exe was started from but gets changed by various Windows APIs including the selected path in the File Dialog box when it is dismissed with a positive acknolledgment (the OK/Load/Save button).
To specify a specific directory as start directory for the new process through SystemExec you have to pass the according start path to it too.
Rolf Kalbermatter  My Blog
Message 21 of 25
(3,394 Views)
hmm, if its the server .exe file, would you expect the failure to occur when running manually from a cmd prompt?   it works fine in that scenario which Is why i thought labview had something to do with it.
Message 22 of 25
(3,388 Views)
Accepted by topic author Moogie
See my edit. It has nothing to do with LabVIEW other than that LabVIEW uses CreateProcess directly and also doesn't mess with its own current directory at all. The command shell will change it whenever you do a successful cd command to whatever directory you changed into (most likely the directory your executable is in when you start it). But SystemExec has an extra parameter to set the start path for the executable which will define it's own current directory. If you leave this empty the created executable will normally inherit the current directory of the process that called CreateProcess(), thus here LabVIEW.
You can make a check in the command shell: Go to a different directory than where your executable is and then start your executable with the absolute path. See if this causes any error.
Message 23 of 25
(3,382 Views)
aahh, gotcha
that fixed it.
thanks
Message 24 of 25
(3,376 Views)
I had this same problem.  I was using the system exec .vi to issue a JTAG programming command to an iMPACT executable.  It worked great for weeks, then all of the sudden stopped working, but only through Labview's System exec.vi; I could still run it manually bring up the command prompt.
Following the advice of adding "cmd /c " (no quotes) before the command into the labview system exec.vi, everything now works the way it used to.  Weird, but I'm happy it works now.
Message 25 of 25
(3,077 Views)
