System Error 31 while loading the LabVIEW Run-Time Engine
I'm getting the following error message.  I've attached a screen shot of it as well.
System Error 31 while loading the LabVIEW Run-Time Engine (<Pathstuff>\\lvrt.dll)
I'm trying to update an instrument running Windows95.  What is system error 31?  I can't find anything on it using Google or the forum's search function.
The instrument is a Romulus-IIIA from Quad Group.  I'm pursuing assistance from them as well.
(3,845 Views)
Accepted by topic author Szandstra
Howdy Szandstra,
Check out this KnowledgeBase article describing what you are seeing.  Follow the steps there to correct the problem.  Have a great day, and let me know if that solution doesn't work for you!
Sincerely,
Chris G in AE
(3,829 Views)
This worked perfectly, thank you.
(3,810 Views)
